smith96
#1 Posted : 11 years ago
smith96
My whirlpool ultimate care II washer will fill but will not agitate thru cycle. I am wondering if it has to do with the lid switch and where it is. Thanks for your help in advance.
fairbank56
#2 Posted : 11 years ago
fairbank56
Groups: Expert
Need your model number to determine that.
Eric
smith96
#3 Posted : 11 years ago
smith96
Eric
i found 2 separate numbers:
LSQ9659PW2
CS1915513
smith96
#4 Posted : 11 years ago
smith96
LSQ9659PW2
CS1915513
MODEL NUMBER: LSQ9659PW2
smith96
#5 Posted : 11 years ago
smith96
MODEL LSQ9659PW2
fairbank56
#6 Posted : 11 years ago
fairbank56
Groups: Expert
Yes, the lid switch on that model affects all motor operation, agitate, drain and spin. Open control panel, lid switch is on the left. Sometimes the hinge screws come loose and won't operate the switch. You can unplug the switch and jump out the two wires (gray and white) to see if washer will work.
Eric
smith96
#7 Posted : 11 years ago
smith96
It turns out that the door hinge was loose. I tightened and closed the lid and it started agitating. Thanks.
revans322 @yahoo.com
#8 Posted : 11 years ago
Are you referring on the left side in the rear of my whirlpool ultimate ll washer? Thank you
Whirlpool Ultimate Care II Washing Machine (Washer Repair)
by Guest 2 years ago
Whirlpool Ultimate Care II LSQ8243HQ0 won't spin (Washer Repair)
by williamlee 4 years ago
Whirlpool Ultimate Care II GSQ9364HQ0 (Washer Repair)
by skylightmissing 5 years ago
Whirlpool Ultimate Care II, how do u remove Agitator Cam? (Washer Repair)
by DieselDavy 5 years ago
whirlpool Ultimate Care II (Washer Repair)
by johnep33333 8 years ago
Whirlpool Ultimate Care II won't spin consistently/maybe not draining? (Washer Repair)
by LauraSpillman 8 years ago
Whirlpool Ultimate Care ii makes strange noise on spin cycle (Washer Repair)
by m042926 10 years ago
Whirlpool Ultimate Care II cycle issues (Washer Repair)
by bisley45 10 years ago
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 10 years ago
Whirlpool Ultimate Care II problem (Washer Repair)
by uri 11 years ago
Whirlpool Ultimate Care II help (Washer Repair)
by eelaroo2 11 years ago
Whirlpool Ultimate Care II wont spin at the end of the cycle....motor humms. (Washer Repair)
by tmv1962 11 years ago
whirlpool ultimate care II washer help!! (Washer Repair)
by baseballmommy3 11 years ago
Whirlpool Ultimate Care II Stuck (Washer Repair)
by thebeginning99 11 years ago
Whirlpool Ultimate Care II Motor Diagnosis (Washer Repair)
by AndyWeg 11 years ago
