handygirl67
#1 Posted : Thursday, March 12, 2015 1:14:03 PM(UTC)
handygirl67
Dryer stopped heating a few months ago. Tested continuity and found thermal cut off was shot. Ordered and installed kit. Dry worked fine until last week. Again tested, ordered and installed thermal cut off and hi limit. After only a few seconds dryer stopped heating again. Again thermal cut off was shot. What would cause the thermal cut off to keep failing?
fairbank56
#2 Posted : Thursday, March 12, 2015 2:32:33 PM(UTC)
fairbank56
Groups: Expert
Poor air flow due to blockage in the ducting (internal and/or external), or leaking drum seals, or blower wheel slipping on motor shaft, or possibly a grounded heater element. If dryer produces heat in air only cycle, element is likely grounded.
Eric
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Whirlpool Dryer Not Heating (Dryer Repair)
by Frustrated42 11/8/2015 7:21:05 AM(UTC)
whirlpool dryer not heating nor timer advancing (Dryer Repair)
by bladrnr 12/26/2013 12:39:41 PM(UTC)
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Whirlpool Dryer not heating (Dryer Repair)
by cindystarr 9/28/2012 2:57:39 PM(UTC)
Whirlpool dryer not heating or turning (Dryer Repair)
by splumer 9/22/2012 10:05:44 AM(UTC)
by ValpoMan 9/17/2012 3:34:11 PM(UTC)
by rdmousaw 8/7/2012 1:03:50 PM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
Whirlpool Dryer not heating well (Dryer Repair)
by rockettme 6/7/2012 9:22:08 AM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
by Phiphtie 1/4/2012 3:09:19 PM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
by scoffman1234 3/16/2011 1:36:37 PM(UTC)
