Hello, My dryer stopped heating up on the automatic cycle, but worked on the other two cycles. A week later none of the cycles heat up. Timer? Thanks, Mike
Groups: APP Team
Hi. Install the jumper wire at BK-R and try. If the heat works - replace the timer Part number: 3976584
