MKrieck
#1 Posted : Sunday, July 22, 2012 6:37:03 PM(UTC)
MKrieck
Hello,
My dryer stopped heating up on the automatic cycle, but worked on the other two cycles. A week later none of the cycles heat up. Timer?
Thanks,
Mike
Simon / APP Team
#2 Posted : Monday, July 23, 2012 10:17:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Install the jumper wire at BK-R and try.
If the heat works - replace the timer Part number: 3976584
Check if the ignitor glows on/off.
Yes - replace the control coils.
If not - check the ignitor, thermal fuse, cycling thermostat, cut off thermal fuse, hi-limit.
Here are the breakdown diagrams and Replacement parts for Whirlpool LGR4634JQ2 GAS DRYER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
by scoffman1234 3/16/2011 1:36:37 PM(UTC)
Whirlpool Dryer not heating up (Dryer Repair)
by mmatrull 8/3/2010 6:26:48 PM(UTC)
