jumpnchuck
#1 Posted : Wednesday, October 30, 2013 6:31:51 PM(UTC)
jumpnchuck
whirlpool dryer has been messing up started not heating up then after a couple times restarting it it would heat up . now its not heating up at all just blowing cool air out. hate to have to call a repair man to fix something simple and charge out the but when its prob something simple and cheap. it goes through its cycle and buzz's when it s done just doesn't heat up............before could touch outside of dryer and feel it was warm now its always cold .
#2 Posted : Wednesday, October 30, 2013 11:10:17 PM(UTC)
Parts for Whirlpool WED5100VQ1 Dryer - AppliancePartsPros.com
Unplug the unit and check the heating coil with a meter.
Should be in the 8 to 12 ohm range.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
