whirlpool dryer has been messing up started not heating up then after a couple times restarting it it would heat up . now its not heating up at all just blowing cool air out. hate to have to call a repair man to fix something simple and charge out the but when its prob something simple and cheap. it goes through its cycle and buzz's when it s done just doesn't heat up............before could touch outside of dryer and feel it was warm now its always cold .
Here are your parts Parts for Whirlpool WED5100VQ1 Dryer - AppliancePartsPros.comUnplug the unit and check the heating coil with a meter. Should be in the 8 to 12 ohm range. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
