scoffman1234
#1 Posted : Wednesday, March 16, 2011 1:36:37 PM(UTC)
scoffman1234
Runs but won't heat up
#2 Posted : Thursday, March 17, 2011 2:01:15 AM(UTC)
Here are your parts.
Replacement parts for WHIRLPOOL GEQ8811LW0 | AppliancePartsPros.com
See the attachment for the wiring diagram. It is for a LW1, could not find one for a LW0 but it should be close or the same as yours.
First check the power to the unit. The motor etc. will run on 120 volts but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If power is OK then unplug the unit and check the heater and thermostats using a meter and resistance.
If the thermal cut-off is open, get back to the forum as there are other things you should check before replacing it.
If OK
If OK
File Attachment(s):
GEQ9811.pdf (253kb) downloaded 15 time(s).
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
Whirlpool Dryer not heating up (Dryer Repair)
by mmatrull 8/3/2010 6:26:48 PM(UTC)
