Dryer stopped heating. Drum turns, fuses all ok. I replaced the heating element and the thermostat and still no heat??? What gives?
I cannot find any info on the given model number, please check it.
I would check the power first. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heating element requires the full 240 volts. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. [COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
