DStephens075@aol.com
#1 Posted : Thursday, June 19, 2014 9:54:07 AM(UTC)
Replace the lid switch about a month ago. Yesterday, the machine washed and rinsed the clothes, but did not spin the water out. Now the machine will not wash, rinse or spin. Do you think it is the cycle/timer control?
sidfink43
#2 Posted : Friday, June 20, 2014 11:30:07 AM(UTC)
sidfink43
On some of these models a bad lid switch will stop it from operating after it fills, so check your repair to make sure nothing went wrong, and by pass the lid switch to make certain nothing is wrong with it.
If that checks out check the pump for an obstruction. Assuming this is a direct drive Whirlpool the fact that it will not drain means the motor is not working, so check those connections. A new timer may be the solution, since the motors are pretty good and rearely fail, but that also could be your problem.
Kenmore Washing Machine Model 417.29042992 (Washer Repair)
by jimylegg1 8/10/2020 5:39:45 PM(UTC)
Sears Kenmore Washing Machine 80 Series (Washer Repair)
by purecountry1127 11/4/2015 8:11:31 AM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
Kenmore washing machine, agitates while filling. (Washer Repair)
by Scott Eddy 6/2/2014 7:54:12 AM(UTC)
kenmore washing machine only fills (Washer Repair)
by stevieray2 6/7/2013 5:44:04 PM(UTC)
Kenmore washing machine (Washer Repair)
by MichelleM74 1/12/2013 11:51:42 AM(UTC)
kenmore washing machine top load (Washer Repair)
by bigfig 6/19/2012 4:56:24 AM(UTC)
Series 90 Kenmore washing machine NO COLD WATER (Washer Repair)
by Char H 5/10/2012 8:29:36 PM(UTC)
kenmore washing machine wont start (Washer Repair)
by buddy93 2/8/2012 2:20:20 PM(UTC)
Kenmore washing Machine (Washer Repair)
by sstrueblue 12/18/2011 5:54:52 PM(UTC)
Kenmore Washing Machine Timer Shaft (Washer Repair)
by GLion 6/1/2011 8:27:48 PM(UTC)
My Kenmore Washing Machine (Washer Repair)
by ignefeus 5/23/2011 6:49:06 AM(UTC)
kenmore washing machine (Washer Repair)
by ron walburn 2/16/2011 8:14:57 AM(UTC)
kenmore washing machine series 70 (Washer Repair)
by raineywillow 9/22/2010 5:26:49 PM(UTC)
Kenmore Washing machine (Washer Repair)
by bjhamrick 5/25/2010 8:37:48 PM(UTC)
