GaryW525
#1 Posted : Wednesday, June 19, 2013 9:35:15 PM(UTC)
GaryW525
Washer shakes so much during spin cycle that it hits the side walls. There's alot of play in the drum.
fairbank56
#2 Posted : Thursday, June 20, 2013 4:07:11 AM(UTC)
fairbank56
Groups: Expert
Need the correct model number of your washer. Usually on nameplate under lid on tub rim or on back of washer.
Eric
GaryW525
#3 Posted : Thursday, June 20, 2013 5:49:18 AM(UTC)
GaryW525
LXR9245EQ0 is the model. Sorry got confused
fairbank56
#4 Posted : Thursday, June 20, 2013 10:59:27 AM(UTC)
fairbank56
Groups: Expert
Is the "play in the drum", play in the inner tub relative to the outer tub or the outer tub? If inner tub, remove agitator and check the drive block. If outer tub, remove the cabinet and check suspension springs, placement of skate plate and/or damper pads on skate plate and base assembly. Here is the parts manual for your washer.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20881364.pdf
See page 5 for reference to drive block and page 8 for suspension parts.
Eric
Inglis direct drive washer shakes and vibrates (Washer Repair)
by yellowcat08 7/14/2019 5:19:41 PM(UTC)
washer shakes at high rpm (Washer Repair)
by lorie r 3/9/2017 5:09:08 AM(UTC)
GE top load washer shakes & clunks during agitation (Washer Repair)
by MikeWest 7/13/2015 7:13:39 AM(UTC)
Washer shakes and shimmies when spinning (Washer Repair)
by whatsthepart 3/1/2013 11:55:52 AM(UTC)
Maytag washer shakes violently during spin cycle (Washer Repair)
by Shapling 2/11/2013 10:04:10 AM(UTC)
washer shakes when spinning (Washer Repair)
by ceeyahd1 4/23/2012 7:02:52 PM(UTC)
Roper top load washer shakes violently...HELP. (Washer Repair)
by Hexster 8/27/2011 5:12:56 PM(UTC)
Washer shakes violently on spin (Washer Repair)
by Wayne Brashear 7/31/2011 6:51:13 AM(UTC)
Kenmore washer shakes like crazy (Washer Repair)
by etbrown4 5/22/2011 8:15:05 PM(UTC)
Kenmore washer shakes violently during spin (Washer Repair)
by mauckbros 10/23/2010 11:21:41 AM(UTC)
Kenmore Washer Shakes violently during spin cycle (Washer Repair)
by thielen25 5/14/2010 12:44:13 PM(UTC)
Roper washer shakes BAD! (Washer Repair)
by Amanda626 8/19/2009 9:52:39 AM(UTC)
washer shakes during spin cycle (Washer Repair)
by 11newhouse 2/26/2009 3:54:17 PM(UTC)
washer shakes violently sometimes while spinning (Washer Repair)
by dconradj 11/9/2008 11:15:48 AM(UTC)
Washer Shakes A Lot (Washer Repair)
by LAXTON 10/30/2008 2:25:15 PM(UTC)
