My washer shakes when spinning, I took the cover off and noticed the suspension spring came off, I put it back on and it happened a few more times in the last fe month so today I ordered 3 of each spring and retainer clip, tub spring and leveling spring. Is there anything else that would cause the spring to come off? even with all springs on the washer tub still seems a little whobbly but then I am not a tech. and it could be normal but spring coming off is getting to be a problem. Are there any pictures showing how the clips are supposed to be installed?
Thanks for your help.
Anyone with help on this?
