lorie r
#1 Posted : Thursday, March 9, 2017 5:09:08 AM(UTC)
lorie r
Washer shakes on spin when it reaches top rpm. Have replaced snubber ring and springs, didn't change anything. Washer is level and does this with no laundry in tub. HELP!
jimctec
#2 Posted : Thursday, March 9, 2017 7:59:55 AM(UTC)
jimctec
Most washers shake; how badly does yours? Does it move around on the floor? Lift the whole top so you can watch it spin; is the basket moving around in the tub or staying centered as it spins? Does it feel loose at all? You might remove the agitator and check/tighten the bolts that hold the basket to the hub...:cool:
