daire Ice Maker - Replaced RE:AP3963432 (241685703) - Water dispenser actuator and when I put the frig back together the ice will not dispense Why? Model #: PLHS269ZDB2
Groups: APP Team
hi.
Check if the ice actuator is actually touching the button behind it when pressed. Check the connector to the control board. Check if the wires are not pinched.
Simon.
We can hear the electronics part trying to work but the ice dropper is not turning and so the ice won't fall out.
Groups: APP Team
HI.
What was the reason to replace the actuator?
Simon.
