This stove popped the circuit breaker once a few days ago. Then it popped it again. I reset and used it. When I went to shut off the oven (hit cancel) it continued to run. I had to unplug the oven to stop it from heating. I don't know what to do. :confused: Help any ideas?
Groups: APP Team
Hi. Pull the range out and check the wiring harness from the clock to the ignitor for the broken insulation and possible contact with the frame. If everything checks out OK - replace the control board Part number: 74009150
