ssmith11
#1 Posted : Monday, August 27, 2012 3:39:26 PM(UTC)
ssmith11
This stove popped the circuit breaker once a few days ago. Then it popped it again. I reset and used it. When I went to shut off the oven (hit cancel) it continued to run. I had to unplug the oven to stop it from heating. I don't know what to do. :confused: Help any ideas?
Simon / APP Team
#2 Posted : Monday, August 27, 2012 4:15:44 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull the range out and check the wiring harness from the clock to the ignitor for the broken insulation and possible contact with the frame. If everything checks out OK - replace the control board Part number: 74009150
Here are the breakdown diagrams and Replacement parts for Maytag MGR5755QDW RANGE- S/C F/S GAS | AppliancePartsPros.com
Post the results.
Simon.
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by cap424646 5/9/2012 5:53:54 PM(UTC)
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
Whirlpool Double Oven Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by Bobmmm 2/7/2012 8:22:08 PM(UTC)
by oldschoolmc 1/4/2012 1:17:53 AM(UTC)
Kenmore oven won't turn off - recall (Oven Repair (including Ranges and Cooktops))
by genghiskhan 12/9/2011 11:02:28 AM(UTC)
oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Debrab 6/5/2010 2:17:58 PM(UTC)
Kitchenaid Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Jane D 4/14/2010 7:01:04 PM(UTC)
by buster42 12/18/2009 4:07:01 AM(UTC)
by camorasch 12/7/2009 2:31:40 PM(UTC)
Set-in oven won't turn off. (Oven Repair (including Ranges and Cooktops))
by tdtk42 11/6/2009 7:29:02 AM(UTC)
by danieltravagliante 7/26/2009 10:52:14 AM(UTC)
Whirlpool oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Pat LaPorte 6/24/2009 8:45:36 PM(UTC)
by JDMACRAE 6/22/2009 6:30:20 PM(UTC)
by rg99 3/2/2009 3:22:59 PM(UTC)
