cap424646
#1 Posted : Wednesday, May 9, 2012 5:53:54 PM(UTC)
cap424646
I got done using the oven and turned it off. I started smelling something hot so I looked in the oven. The broiler was on. The only way to get it to turn off is by killing the breaker. Any ideas?
#2 Posted : Friday, May 11, 2012 3:54:32 AM(UTC)
A model number may help others help you.
Sounds like the relay contacts that control the broiler are welded shut.
I am assuming that the broiler is on full high heat.
#3 Posted : Friday, May 11, 2012 3:55:16 AM(UTC)
Also could be that the electronics that control the broil relay are always on.
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
oven won't turn off (Oven Repair (including Ranges and Cooktops))
by ssmith11 8/27/2012 3:39:26 PM(UTC)
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
Whirlpool Double Oven Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by Bobmmm 2/7/2012 8:22:08 PM(UTC)
by oldschoolmc 1/4/2012 1:17:53 AM(UTC)
Kenmore oven won't turn off - recall (Oven Repair (including Ranges and Cooktops))
by genghiskhan 12/9/2011 11:02:28 AM(UTC)
by Debrab 6/5/2010 2:17:58 PM(UTC)
Kitchenaid Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Jane D 4/14/2010 7:01:04 PM(UTC)
by buster42 12/18/2009 4:07:01 AM(UTC)
by camorasch 12/7/2009 2:31:40 PM(UTC)
Set-in oven won't turn off. (Oven Repair (including Ranges and Cooktops))
by tdtk42 11/6/2009 7:29:02 AM(UTC)
by danieltravagliante 7/26/2009 10:52:14 AM(UTC)
Whirlpool oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Pat LaPorte 6/24/2009 8:45:36 PM(UTC)
by JDMACRAE 6/22/2009 6:30:20 PM(UTC)
by rg99 3/2/2009 3:22:59 PM(UTC)
