I got done using the oven and turned it off. I started smelling something hot so I looked in the oven. The broiler was on. The only way to get it to turn off is by killing the breaker. Any ideas?
A model number may help others help you.
Sounds like the relay contacts that control the broiler are welded shut. I am assuming that the broiler is on full high heat. |
THIS FORUM IS DEAD!!!!!!! |
Also could be that the electronics that control the broil relay are always on. |
