kevindean
#1 Posted : Monday, April 23, 2012 8:15:13 PM(UTC)
kevindean
Hello. I replaced a bad heating element about 3 months ago, and now it has stopped working again. The heating element looks OK (no broken coils). I have a volt meter, but don't know where to start checking, or what reading to check for?
Thank you
#2 Posted : Tuesday, April 24, 2012 1:57:24 AM(UTC)
A model number may help others help you.
I would start by checking the power.
The motor runs off of 120 volts but the heater requires the full 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK then check the various thermostats in the unit.
All of them should be closed at room temperature.
Jenn Air - Heating Element not Working (Dishwasher Repair)
by sgsims 11/9/2020 6:18:47 PM(UTC)
Kitchenaid KDTE204DSS0 Dishwasher Heating Element not working (Dishwasher Repair)
by mthornton601 6/26/2019 4:02:27 PM(UTC)
Heating Element Not Working? (Dishwasher Repair)
by agdodge4x4 8/22/2017 5:05:56 PM(UTC)
Electrolux heating element not working (Refrigerator & Freezer Repair)
by robmichael 7/28/2014 8:59:40 PM(UTC)
Heating element not working (Oven Repair (including Ranges and Cooktops))
Belarus swimtime 6/16/2013 12:05:28 PM(UTC)
Whirlpool Heating Element Not Working (Dishwasher Repair)
by muegge99 3/27/2013 4:27:13 PM(UTC)
Whirlpool Oven - lower heating element not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by martinezpaul1 1/28/2013 4:07:32 PM(UTC)
by yakoo11 4/9/2012 6:34:38 PM(UTC)
Heating Element not working (Oven Repair (including Ranges and Cooktops))
by njbaker7 4/9/2012 9:40:48 AM(UTC)
Jenn-Air Heating Element Not Working (Oven Repair (including Ranges and Cooktops))
by rkoster 6/20/2011 5:44:31 AM(UTC)
Dryer heating element not working (Dryer Repair)
by srowbotham 3/30/2011 7:12:17 PM(UTC)
Kenmore Dishwasher heating element not working (Dishwasher Repair)
by Xray 12/10/2010 8:39:23 AM(UTC)
by sfuller 12/4/2010 10:11:17 AM(UTC)
OVEN - Bake heating element not working (Oven Repair (including Ranges and Cooktops))
by lynnadiv 11/18/2010 9:51:03 AM(UTC)
Heating element not working in wash cycle (Dishwasher Repair)
by gerg 8/16/2009 9:20:34 PM(UTC)
