martinezpaul1
#1 Posted : Monday, January 28, 2013 4:07:32 PM(UTC)
martinezpaul1
Hi there (Gene?)
We used the self cleaning feature of our oven for the first time ever. Had a little trouble with the locking lever and its possible that the internal mechanism which allows heating was damaged. (I can post an image if that helps)
In any event, the lower coil does not heat up any longer. Top works fine. All physical connections are intact and connected.
Can you please offer your expertise on how I can repair?
Many thanks,
Paul
#2 Posted : Tuesday, January 29, 2013 1:12:11 PM(UTC)
Hi Paul,
You may want to start the troubleshooting from checking that heating element for continuity.
The model number you posted is incorrect. Please verify and repost it.
martinezpaul1
#3 Posted : Saturday, February 2, 2013 11:31:20 AM(UTC)
martinezpaul1
Thank you Gene, for your response.
The correct model number is RB260PXBQ2. Sorry for the earlier mistype.
Additionally, I am posting a picture of the oven lock assembly. I have a feeling something is broken/missing. Perhaps a spring?
Thank you again for your help.
Paul
martinezpaul1 attached the following image(s):
#4 Posted : Tuesday, February 5, 2013 1:11:41 PM(UTC)
Hi Paul,
I do not think the latch has something to do with the Bake element not heating.
If the heating element itself is good and there is nothing wrong with the wires then the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer.
- The oven Bake element Part number: 308180
