vclucpr
#1 Posted : Wednesday, January 16, 2008 10:19:54 AM(UTC)
vclucpr
Washer does everything but when it gets to rinse and spin mode it stops. this happens in all cycles.:confused:
abbie
#2 Posted : Wednesday, January 16, 2008 12:43:22 PM(UTC)
abbie
Check your lid cover to see if the strike is broken off.If it,s there, then check your lid switch with a pencil to see if it is making a clicking sound.If it,s not making a noise replace the switch
vclucpr
#3 Posted : Thursday, January 17, 2008 9:24:50 AM(UTC)
vclucpr
Yes it is clicking.
vclucpr
#4 Posted : Thursday, January 17, 2008 12:57:26 PM(UTC)
vclucpr
when in spin mode you hear a humming noise. i opened lid and humming stoped.took of front cover and belt is there. motor gets hot.
#5 Posted : Thursday, January 17, 2008 5:12:46 PM(UTC)
Your tranny probably locked up in spin. Pull the belt off and turn pulley in spin direction, if hard to turn, the internal brakes are not releasing, or there is something stuck in the tub.
Frigadaire top-loader agitates, but does not spin. (Washer Repair)
by shj723 3/27/2017 5:07:37 PM(UTC)
Washer fills but does not spin (Washer Repair)
by RockIsle 3/7/2017 8:32:44 PM(UTC)
GE Profile does not spin or agitate (Washer Repair)
by mailachefski 8/16/2016 7:43:44 PM(UTC)
Samsung Washer does not spin (Washer Repair)
by SwimKatie 3/22/2016 5:51:48 PM(UTC)
Agitator does not spin at rinse cycle (Washer Repair)
by Nikkev195719 12/14/2015 4:18:24 PM(UTC)
Washer spins fine when empty but does not spin when loaded (Washer Repair)
by notgoodatrepairs 7/22/2015 5:08:43 PM(UTC)
Maytag does not spin fast enough to dry clothes (Washer Repair)
by Dave69tbfst 7/7/2015 11:49:15 AM(UTC)
Frigidaire Front Washer does not spin - intermittent issue (Washer Repair)
by jamesm113 6/23/2015 9:13:55 PM(UTC)
Kenmore 80 washer agitates but does not spin or drain but timer completes cycles (Washer Repair)
by dmdlargo 6/8/2015 6:50:26 AM(UTC)
Kenmore 90 washer does not spin (Washer Repair)
by ChdoulaDIY 5/31/2015 1:39:29 AM(UTC)
Agitator will not turn and drum does not spin. (Washer Repair)
by jakej 4/22/2015 10:20:05 AM(UTC)
by RoyD 10/15/2014 10:24:49 AM(UTC)
Whirpool Washer hums but does not spin (Washer Repair)
by markob 6/27/2014 7:20:54 AM(UTC)
Does not spin properly (Washer Repair)
by rdtansley 3/15/2014 3:05:36 PM(UTC)
Kenmore 70 series washer agitates but does not spin (Washer Repair)
by tismichael 11/16/2013 2:02:16 PM(UTC)
