Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Washer fills, agitates, drains, but does not spin. I checked the motor coupler and it appears to be fully intact and no cracks. While checking the motor coupler I manually turned the coupler and it was able to move freely in the counter clockwise direction, but had limited movement when turned in the clockwise direction. After manually turning the coupler, the spin cycle worked for one cycle, then stopped. Any suggestions are appreciated.
