vclucpr
#1 Posted : Wednesday, January 16, 2008 10:19:54 AM(UTC)
vclucpr
Washer does everything but when it gets to rinse and spin mode it stops. this happens in all cycles.:confused:
abbie
#2 Posted : Wednesday, January 16, 2008 12:43:22 PM(UTC)
abbie
Check your lid cover to see if the strike is broken off.If it,s there, then check your lid switch with a pencil to see if it is making a clicking sound.If it,s not making a noise replace the switch
vclucpr
#3 Posted : Thursday, January 17, 2008 9:24:50 AM(UTC)
vclucpr
Yes it is clicking.
vclucpr
#4 Posted : Thursday, January 17, 2008 12:57:26 PM(UTC)
vclucpr
when in spin mode you hear a humming noise. i opened lid and humming stoped.took of front cover and belt is there. motor gets hot.
#5 Posted : Thursday, January 17, 2008 5:12:46 PM(UTC)
Your tranny probably locked up in spin. Pull the belt off and turn pulley in spin direction, if hard to turn, the internal brakes are not releasing, or there is something stuck in the tub.
Guest (5)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
Maytag Toploader Agitates but does not Spin (Washer Repair)
by Guest 10/3/2023 4:51:35 PM(UTC)
Maytag Centennial 2010 Top Load does not spin (Washer Repair)
by Guest 8/20/2023 4:45:18 PM(UTC)
Maytag A412 does not spin (Washer Repair)
by gawhitemt 4/7/2022 4:11:47 PM(UTC)
Maytag Agitator rotates but tub does not spin (Washer Repair)
by Poomse 10/27/2020 5:35:42 PM(UTC)
Whirlpool Washer Agitates and Drains but does not spin (Washer Repair)
by DoItYourselfDan 4/9/2019 11:06:11 AM(UTC)
Frigadaire top-loader agitates, but does not spin. (Washer Repair)
by shj723 3/27/2017 5:07:37 PM(UTC)
Washer fills but does not spin (Washer Repair)
by RockIsle 3/7/2017 8:32:44 PM(UTC)
GE Profile does not spin or agitate (Washer Repair)
by mailachefski 8/16/2016 7:43:44 PM(UTC)
Samsung Washer does not spin (Washer Repair)
by SwimKatie 3/22/2016 5:51:48 PM(UTC)
Agitator does not spin at rinse cycle (Washer Repair)
by Nikkev195719 12/14/2015 4:18:24 PM(UTC)
Washer spins fine when empty but does not spin when loaded (Washer Repair)
by notgoodatrepairs 7/22/2015 5:08:43 PM(UTC)
Maytag does not spin fast enough to dry clothes (Washer Repair)
by Dave69tbfst 7/7/2015 11:49:15 AM(UTC)
Frigidaire Front Washer does not spin - intermittent issue (Washer Repair)
by jamesm113 6/23/2015 9:13:55 PM(UTC)
Kenmore 80 washer agitates but does not spin or drain but timer completes cycles (Washer Repair)
by dmdlargo 6/8/2015 6:50:26 AM(UTC)
