papermind
#1 Posted : Monday, July 27, 2009 10:25:09 AM(UTC)
papermind
We have a Maytag Atlantis MAV7200AWW that will not drain. I have taken it apart the only parts that look like they could be the cause are the belt and pump. The pump seems ok but how free spinning should the pulley be?
sidfink43
#2 Posted : Tuesday, July 28, 2009 5:22:17 PM(UTC)
sidfink43
Hi Papermind
There are only three reasons why your machine will not drain.
1. The belt is not turning the pump. You can observe whether or not this is happening by operating the machine with the front off. I assume you have done this and determined this is not the problem.
2. The drain system is clogged. Take off the pump and make sure nothing is blocking water from draining.
3. The pump is bad. This is likely your problem. There is a new design for this pump, here is the Maytag technical bulletin for it.
http://www.servicematters.com/m...ary/docs/ITDL-0031-B.pdf
I would say replace the pump and you should be fine.
Good luck
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
