Hello,
My Whirlpool thin twin will not drain or spin in the Normal setting, but will function normally in Permanent Press (drain and spin). So weird, any help would be appreciated. Does that sound like a lid switch issue? Thanks!!
Groups: Expert
Thanks fairbank56! I'll give that a try.
Originally Posted by: rober luck  Thanks fairbank56! I'll give that a try. I have a samsung front load washer that won't drain. I replaced the pump and the circuit board but no luck. Washer goes through all cycles, except draining. Any ideas?
