rober luck
#1 Posted : Monday, April 20, 2015 9:10:47 AM(UTC)
rober luck
Hello,
My Whirlpool thin twin will not drain or spin in the Normal setting, but will function normally in Permanent Press (drain and spin). So weird, any help would be appreciated. Does that sound like a lid switch issue? Thanks!!
fairbank56
#2 Posted : Monday, April 20, 2015 10:02:15 AM(UTC)
fairbank56
Groups: Expert
rober luck
#3 Posted : Monday, April 20, 2015 10:15:58 AM(UTC)
rober luck
Thanks fairbank56! I'll give that a try.
Rakzo3000
#4 Posted : Monday, April 20, 2015 3:48:15 PM(UTC)
Rakzo3000
I have a samsung front load washer that won't drain. I replaced the pump and the circuit board but no luck. Washer goes through all cycles, except draining. Any ideas?
