Clement A
#1 Posted : Sunday, July 12, 2009 9:31:36 PM(UTC)
Clement A
The ice maker works but does not dispense water. I replaced the water filter. There is no water at the union/elbow at the bottom of the freezer door. I can here a humming sound when the water lever is depressed.
woodchuckie
#2 Posted : Monday, July 13, 2009 5:59:25 AM(UTC)
woodchuckie
Disconnect the water line where it comes out of the water inlet valve on the back of the unit and see if water comes out there when you try the dispenser. That valve may be bad. One side of it can work and the other not.
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
Frigidaire side by side door fridge- timer question (Refrigerator & Freezer Repair)
by Chickadee 10/3/2016 5:00:58 PM(UTC)
Frigidaire Side By Side Compressor Will Not Start (Refrigerator & Freezer Repair)
by stockler707 7/17/2015 5:56:31 AM(UTC)
Frigidaire side by side, freezer temp erratic, fresh is ok (Refrigerator & Freezer Repair)
by nigelquest 12/27/2014 10:47:11 AM(UTC)
Frigidaire Side by Side not cooling (Refrigerator & Freezer Repair)
by mrmagic 12/2/2014 10:13:52 AM(UTC)
Frigidaire Side By Side not cooling to set temp (Refrigerator & Freezer Repair)
by Jedi.Cowboy 11/26/2014 6:48:31 AM(UTC)
Frigidaire side by side won't defrost (Refrigerator & Freezer Repair)
by scmiller 11/13/2014 9:06:57 AM(UTC)
Frigidaire side by side not cooling may be defrost problem (Refrigerator & Freezer Repair)
by ScotB48116 8/5/2014 9:29:43 AM(UTC)
Frigidaire side by side ice maker/freezer issues (Refrigerator & Freezer Repair)
by franchz 7/16/2014 6:20:00 PM(UTC)
Frigidaire side by side not cooling properly (Refrigerator & Freezer Repair)
by RodH508 7/6/2014 10:48:38 AM(UTC)
Frigidaire Side by side fridge not cooling properly (Refrigerator & Freezer Repair)
by Lebbrin 1/1/2014 1:24:48 PM(UTC)
Frigidaire side by side refrigerator not cooling (Refrigerator & Freezer Repair)
by ducatiduke 12/22/2013 8:42:21 PM(UTC)
Frigidaire Side by Side Running 24/7 (Refrigerator & Freezer Repair)
by jhknight 9/8/2013 7:37:01 PM(UTC)
Frigidaire side by side Freezer not Freezing (Oven Repair (including Ranges and Cooktops))
by ac132675 7/25/2013 10:24:45 AM(UTC)
