mrmagic
#1 Posted : Tuesday, December 2, 2014 10:13:52 AM(UTC)
mrmagic
I have a fridgidaire side by side that has stopped cooling & freezing. The compressor is making a clicking noise???? Does anyone have an idea what this may be????
#2 Posted : Tuesday, December 2, 2014 10:53:43 AM(UTC)
I cannot find any info on the given model number.
Clicking is the compressor trying to start over and over again.
Perhaps the following will help.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Note the compressor winding resistance test can tell you that a compressor is bad. It does not tell you that the compressor is good as it may have other internal problems.
If the compressor measures OK and then try replacing the start device.
It may be obvious that it is shot and there is not a good way to test it.
This may be a sealed system problem re: compressor, so check your warranty. Often the sealed system has a longer warranty.
mrmagic
#3 Posted : Tuesday, December 2, 2014 11:04:20 AM(UTC)
mrmagic
Ok thanks.....I called my parts supply store & thwy couldnt find that model # either.....its kind of weird. Thanks for the info though
Frigidaire Side By Side not cooling to set temp (Refrigerator & Freezer Repair)
by Jedi.Cowboy 11/26/2014 6:48:31 AM(UTC)
Frigidaire side by side not cooling may be defrost problem (Refrigerator & Freezer Repair)
by ScotB48116 8/5/2014 9:29:43 AM(UTC)
Frigidaire side by side not cooling properly (Refrigerator & Freezer Repair)
by RodH508 7/6/2014 10:48:38 AM(UTC)
Frigidaire side by side not cooling or water dispensing (Refrigerator & Freezer Repair)
by btatum 7/24/2011 8:59:57 AM(UTC)
Frigidaire Side by Side Not Cooling (Refrigerator & Freezer Repair)
by chaaur 12/14/2010 6:30:47 AM(UTC)
frigidaire side by side not cooling (Refrigerator & Freezer Repair)
by GK1Racing 7/11/2010 3:46:05 AM(UTC)
