StanH
#1 Posted : Saturday, June 20, 2009 8:48:32 AM(UTC)
StanH
Water dispenser will not shut off on occassion. I suspect the watrer valve is freezing since running warm air over the back panel frees it up. Is replacing the valve the answer or is there a more insidious problem?
applianceman
#2 Posted : Saturday, June 20, 2009 9:02:55 AM(UTC)
applianceman
I would say that the valve is the problem. Hope this helps!
Refrigerator repair guide
Bosch Refrigerator Water Valve Stuttering (Refrigerator & Freezer Repair)
by Mattman928 4/14/2020 1:25:14 AM(UTC)
Water valve chatter/low output (Refrigerator & Freezer Repair)
by mmisko 2/3/2020 10:00:58 AM(UTC)
Use other water valves (Washer Repair)
by zuki1100 4/18/2019 3:53:11 PM(UTC)
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 4/13/2019 9:06:58 AM(UTC)
Voltages/Signal going to water valve (Refrigerator & Freezer Repair)
by PT2000 6/13/2017 8:14:51 AM(UTC)
Would you change water valves? (Washer Repair)
by NSXBill 3/10/2017 2:44:04 PM(UTC)
Leaking Water Valve W10340983 (Refrigerator & Freezer Repair)
by doubldc 2/9/2017 9:40:08 PM(UTC)
Hot Water valve in home (Washer Repair)
by Amana_watt? 1/19/2016 8:36:25 PM(UTC)
New GE dishwasher - leaking at water valve (Dishwasher Repair)
by cbrandel 7/29/2015 7:25:31 AM(UTC)
How to access the water valve (Dishwasher Repair)
by bradawk 3/13/2015 4:18:08 PM(UTC)
Water valve question (Dishwasher Repair)
by rich22 2/26/2015 4:51:52 PM(UTC)
ice maker water valve (Refrigerator & Freezer Repair)
by doug1512 11/23/2014 10:33:57 AM(UTC)
Jenn-Air/Whirlpool Free Standing Ice Maker Water Valve (Refrigerator & Freezer Repair)
by mjbosha 9/12/2014 4:21:51 AM(UTC)
Do I need to relpace Inlet Water Valve? How? (Washer Repair)
by rodrigt 8/14/2014 11:04:11 PM(UTC)
Dual water valve (Refrigerator & Freezer Repair)
by mikegayron 7/25/2014 8:13:55 PM(UTC)
