Samsung Refrig RF 4289HARS/XAA. Replaced inlet valve, DA97-07827B, and double checked solenoid valves, all good, and still have chatter.and water output is about 1/2 . I’m thinking it must b a restriction somewhere. I have all the hoses disconnected and all blow thru except the LARGE white one. I don’t know how the routing goes to what. Also new filter doesn’t help. Couldn’t find a way to insert pics from site. Any help is appreciated.
Disregard my original post .Well after rechecking everything, blowing tubing out and replacing filter, all is right with the world.
