TxVet
#1 Posted : Saturday, June 6, 2009 5:31:15 PM(UTC)
TxVet
Please help. My wife was pulling out the bottom tray and the spray arm underneath got hung on the tray and she broke the plastic bolt that help the lower spray arm in place. I ordered a new bolt and put all back together. However, the bolt gets tight before the lower spray assembly gets tight and then when the spray arm turns, it keeps getting hung in the lower basket. When I put it back, there was a plastic race that went on first, then the spray hub, then a plastic ring, then the bolt. Should there be another spacer or washer that allows the bolt to hold the lower spay hub tighter so it does not wobble?
#2 Posted : Monday, June 8, 2009 3:14:06 AM(UTC)
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Kitchen Aid Dishwasher Upper Spray Arm (Dishwasher Repair)
by Guest 1/13/2022 12:58:02 PM(UTC)
whirlpool du850swpb2 spray arm (Dishwasher Repair)
by willyw 12/22/2021 12:31:52 PM(UTC)
Bosch 300 dishwasher - Middle spray arm only active for half-loads??? (Dishwasher Repair)
by Xcessiv 12/9/2020 5:58:19 AM(UTC)
Dishwasher Spray Arms Not Spinning / Not Enough Water [SOLVED] (Dishwasher Repair)
by MontyTWD 10/5/2020 8:05:23 PM(UTC)
KitchenAid KUDS30IXBLA Dishwasher Upper Spray Arms Not Spinning (Dishwasher Repair)
by navagator 8/24/2019 11:58:55 PM(UTC)
Bosch/Gaggeneau Low pressure from spray arms - tried everything (Dishwasher Repair)
by fixitboy 7/27/2019 10:50:29 PM(UTC)
Bosch dishwasher upper spray arm lost O-rings (Dishwasher Repair)
by Daniel J 2/10/2019 11:56:46 AM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 9:28:24 AM(UTC)
upper spray arm screw broken (Dishwasher Repair)
by peabody 11/30/2016 10:47:12 AM(UTC)
Spray Arm Doesn't Turn - Probe Misaligned? (Dishwasher Repair)
by amc2012 4/15/2016 10:17:31 PM(UTC)
Center spray arm not spinning (Dishwasher Repair)
by Moleski 1/26/2016 9:28:31 AM(UTC)
Water Supply Tube & Spray arm dangling (Dishwasher Repair)
by yinger 9/13/2015 11:10:13 AM(UTC)
No pressure in spray arms (Dishwasher Repair)
by Doop007 9/4/2015 7:21:56 AM(UTC)
