The 8-32 screw that secures the upper spray arm broke off in the receptacle It is not listed on the parts lists as a replaceable item I have tried to remove it unsuccesfully How is this receptacle attached to the ceiling of the SS dishwasher
If its welded I'm out of luck and a 2$ screw will cost me a new unit Any help is appreciated for this 1st time poster Thanks Peabody
Groups: Expert
Thanks for the suggestion I have already attempted,and failed to remove the broken part of the screw from the socket area I guess my last chance will be to drill it our the same diameter as the I/S dimension of the spray arm bearing and try to epoxy a new support screw in this manner. Again Thanks
