peabody
#1 Posted : 8 years ago
peabody
The 8-32 screw that secures the upper spray arm broke off in the receptacle
It is not listed on the parts lists as a replaceable item
I have tried to remove it unsuccesfully
How is this receptacle attached to the ceiling of the SS dishwasher
If its welded I'm out of luck and a 2$ screw will cost me a new unit
Any help is appreciated for this 1st time poster
Thanks Peabody
ThatGuy
#2 Posted : 8 years ago
ThatGuy
Groups: Expert
United States
I watched this video and it looks like its part of the tub.
Dishwasher Spray Arm Water Supply Tube (part #WD12X10113)-How To Replace
I've used a Dremel tool to cut a small slot into a screw shaft. Then use a flat blade screwdriver to back out the shaft. It might be worth a try.
peabody
#3 Posted : 8 years ago
peabody
Thanks for the suggestion
I have already attempted,and failed to remove the broken part of the screw from the socket area
I guess my last chance will be to drill it our the same diameter as the I/S dimension of the spray arm bearing and try to epoxy a new support screw in this manner.
Again Thanks
