wapiwulo
#1 Posted : Tuesday, May 24, 2011 6:17:41 AM(UTC)
wapiwulo
wont finish wash stops error code F35 + CHEK SUDS not using too much suds,after unpluging and restarting several times it will finish cycle some times.also blew through water pressure hose its clear,looked at steam board no abnormalities but dont know how to chek.can anyone give me a heads up?THANKS IN ADVANCE!:confused:
Joe / APP Team
#2 Posted : Tuesday, May 24, 2011 11:08:13 AM(UTC)
Joe / APP Team
Wapiwulo,
Did you check or replace the analog pressure switch ?
Part number: AP4323930
Since the air dome hose is clear and you're sure there's no residual suds in the drum, this would be the next step in diagnosing the F35 code and the Suds detect circuit.
Good Luck,
Whirlpool duet steam washer intermittently turns off mid cycle. (Washer Repair)
by jlongo7000 11/19/2021 12:48:58 PM(UTC)
Whirlpool Duet Steam Model WFW9750WW01 (Washer Repair)
by wmsunder 5/9/2020 11:35:23 AM(UTC)
Whirlpool Duet Steam Error Codes (Dryer Repair)
by etamunupe 3/28/2020 5:09:00 AM(UTC)
Whirlpool Duet Steam blinking light and 3 beeps (Washer Repair)
by bigtwisty 11/23/2018 2:15:23 PM(UTC)
Whirlpool Duet Steam Washer - F20 Code (Washer Repair)
by ZMonet 8/15/2016 3:41:38 PM(UTC)
Whirlpool Duet Steam - F20 (Washer Repair)
by Dan.geddes 4/27/2015 6:36:00 PM(UTC)
Whirlpool Duet Steam control light on and washer won't start (Washer Repair)
by Marlene731 11/23/2014 9:41:55 PM(UTC)
whirlpool duet steam not draining (Washer Repair)
by VincentD 7/23/2014 2:18:18 PM(UTC)
Whirlpool Duet Steam Not Starting (Washer Repair)
by lstricker1974 5/29/2014 12:50:52 PM(UTC)
Whirlpool Duet Steam - new dispenser motor needed? (Washer Repair)
by Kbarrett 9/18/2013 12:48:27 PM(UTC)
Whirlpool Duet Steam Dryer had water in vent hose (Dryer Repair)
by dlhord 9/4/2012 4:06:59 PM(UTC)
whirlpool duet steam (Washer Repair)
by bluejohn 8/10/2011 7:46:07 AM(UTC)
Whirlpool Duet Steam Washer F35 display (Washer Repair)
by lesandjimrpr 7/24/2010 11:38:48 AM(UTC)
Whirlpool Duet Steam (Dryer Repair)
by giget2000 10/3/2009 9:54:55 AM(UTC)
Whirlpool Duet Steam Washer Problem (Washer Repair)
by john.d.frank 8/21/2009 9:07:40 AM(UTC)
