jshundley
#1 Posted : 14 years ago
jshundley
My Bosch dryer will operate normally but will not heat. Is there a replacement part to correct the problem?
Jeff / APP Team
#2 Posted : 14 years ago
Jeff / APP Team
First you need to check for proper voltage coming to the dryer. If you have 240 volts, then unplug the dryer and test the heater and fuses for continuity. The should read closed or 0. The one on the side of the heater has a reset button. If this is popped out and you reset it, check you vent system. Here is the part number for the heater kit.
Part number: AP3767226
Mardimar
#3 Posted : 14 years ago
Mardimar
For the part AP3767226, is the thermostat built in? Are there written instructions for installation somewhere? Are they included with the part?
Jeff / APP Team
#4 Posted : 14 years ago
Jeff / APP Team
Yes, it comes with the thermostat. It's not hard to change, just remove front panel and remove screws holding heater assembly in.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 2 years ago
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 4 years ago
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 4 years ago
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 4 years ago
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 4 years ago
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 7 years ago
Dryer won't heat (Dryer Repair)
by ncoles6 8 years ago
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9 years ago
by Kate123 9 years ago
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 9 years ago
by haymon 9 years ago
by wgomezp1 9 years ago
by chash 10 years ago
Gas dryer won't heat (Dryer Repair)
by pino2424 10 years ago
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 10 years ago
