haymon
#1 Posted : 9 years ago
haymon
I have test all the fuses, all test good. Change the timer and still no heat.
Bobbi7007
#2 Posted : 9 years ago
Bobbi7007
Have you checked the heating element? If that is broken, it will need to be replaced.
#3 Posted : 9 years ago
A model number would be useful.
Find your model number - AppliancePartsPros.com
Start by checking the power.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 2 years ago
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 4 years ago
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 4 years ago
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 4 years ago
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 4 years ago
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 7 years ago
Dryer won't heat (Dryer Repair)
by ncoles6 8 years ago
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9 years ago
by Kate123 9 years ago
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 9 years ago
by wgomezp1 9 years ago
by chash 10 years ago
Gas dryer won't heat (Dryer Repair)
by pino2424 10 years ago
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 10 years ago
Admiral Dryer won't heat (Dryer Repair)
by MarkMLP 10 years ago
