AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer won't heat consistently – Is an RCA model dryer actually GE?
Joined: 2/19/2019(UTC) Posts: 0  Location: Silver Spring, MD
The dryer in question has a model info tag for RCA DRB1555RALWH. From the troubleshooting info here, it appears likely to be a thermostat issue. Motor runs and belt is OK; dryer has been throroughly cleaned of excess lint inside. The parts section here shows parts for a model of exact same number, but identified as a GE model. Would this older "RCA" identified model actually be a rebranded GE dryer, at the time it was made and on the market? (Can I safely assume the GE part of same model number is really the correct part?)
Groups: Expert
GE made the RCA and Hotpoint appliances and some of the Sears ones. Check the vent for blockages or limited airflow.
Dryer Repair
