My Bosch dryer will operate normally but will not heat. Is there a replacement part to correct the problem?
First you need to check for proper voltage coming to the dryer. If you have 240 volts, then unplug the dryer and test the heater and fuses for continuity. The should read closed or 0. The one on the side of the heater has a reset button. If this is popped out and you reset it, check you vent system. Here is the part number for the heater kit. Part number: AP3767226
For the part AP3767226, is the thermostat built in? Are there written instructions for installation somewhere? Are they included with the part? Thanks
Yes, it comes with the thermostat. It's not hard to change, just remove front panel and remove screws holding heater assembly in.
