jshundley
#1 Posted : Monday, February 21, 2011 12:14:42 PM(UTC)
jshundley
My Bosch dryer will operate normally but will not heat. Is there a replacement part to correct the problem?
Jeff / APP Team
#2 Posted : Tuesday, February 22, 2011 10:04:44 AM(UTC)
Jeff / APP Team
First you need to check for proper voltage coming to the dryer. If you have 240 volts, then unplug the dryer and test the heater and fuses for continuity. The should read closed or 0. The one on the side of the heater has a reset button. If this is popped out and you reset it, check you vent system. Here is the part number for the heater kit.
Part number: AP3767226
Mardimar
#3 Posted : Monday, February 28, 2011 1:07:11 PM(UTC)
Mardimar
For the part AP3767226, is the thermostat built in? Are there written instructions for installation somewhere? Are they included with the part?
Jeff / APP Team
#4 Posted : Tuesday, March 1, 2011 3:47:28 AM(UTC)
Jeff / APP Team
Yes, it comes with the thermostat. It's not hard to change, just remove front panel and remove screws holding heater assembly in.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
