Someone in the past bypassed the hi limit switch, so i ohm'd out the switch and found that it was stuck open. I replaced the switch and wired it back the right way. Now we are getting a code F3 which im told means hi limit switch. What could be throwing off the hi limit?
THIS FORUM IS DEAD!!!!!!! |
