Brian Breazeale
#1 Posted : Sunday, November 16, 2008 4:25:53 PM(UTC)
Brian Breazeale
The control panel (clock) stopped working, therer was a buzzing noise behind control panel.
I removed cover and found the relay board (controls the fan and the door lock) buzzing. I replaced the main control board. oven works but fan did not. After further checks found fan motor coils open, burnt and found that the relay board was not suppling voltage to the fan. At this point i am planning an replacing the relay board and the fan motor. any ideas what caused these problems??
Note: the door lock portion of the relay board works.
Thanks Brian
#2 Posted : Monday, November 17, 2008 1:31:15 AM(UTC)
Your motor probably shorted while burning out, causing the relay to burn out.
Jenn-Air wall oven clock blinks (Oven Repair (including Ranges and Cooktops))
by papaaustin 1/30/2013 9:52:57 AM(UTC)
Jenn-Air Wall Oven buzzes and no Display (Oven Repair (including Ranges and Cooktops))
by Joey32 11/15/2011 9:12:08 AM(UTC)
Jenn-Air wall oven - No Display (Oven Repair (including Ranges and Cooktops))
by randykluber 8/24/2011 8:25:38 AM(UTC)
Jenn-Air wall oven (Oven Repair (including Ranges and Cooktops))
by lindellmusic 1/27/2011 5:43:25 PM(UTC)
Jenn-Air Wall Oven - Beeps with Code 'FC' (Oven Repair (including Ranges and Cooktops))
by Janmon 10/27/2010 3:12:16 PM(UTC)
Jenn-air wall oven not maintaining target heat (Oven Repair (including Ranges and Cooktops))
by rhiller 9/21/2010 8:48:03 AM(UTC)
W141 Wiring Diagram - Jenn-Air Wall Oven (Oven Repair (including Ranges and Cooktops))
by dugantr1 11/14/2009 5:10:18 AM(UTC)
Jenn-Air Wall Oven - Electronic Control Convection (Oven Repair (including Ranges and Cooktops))
by Cilly 11/9/2009 1:45:57 PM(UTC)
Jenn-air wall oven control panel noty working (Oven Repair (including Ranges and Cooktops))
by fritz 10/8/2009 8:44:55 AM(UTC)
by Mike Hallada 10/3/2009 12:14:35 PM(UTC)
Jenn-Air Wall Oven Light Won't Go Off (Oven Repair (including Ranges and Cooktops))
by ThorntonCJ 8/29/2009 12:09:14 PM(UTC)
F3 error on Jenn-Air Wall Oven (Oven Repair (including Ranges and Cooktops))
by lopez 6/26/2009 5:17:07 AM(UTC)
Jenn-Air Wall Oven display (Oven Repair (including Ranges and Cooktops))
by tyke58 11/8/2007 7:49:46 AM(UTC)
