Cilly
#1 Posted : Monday, November 9, 2009 1:45:57 PM(UTC)
Cilly
I just bought a used Jenn-Air Convection Wall Oven - Electronic Control. We are trying to connect it however we don't have a wiring diagram for it. What's throwing us for a loop is the extra blue wire. Do you know what that wire is for?
Does it need a seperate fuse box like our counter cook top has?
#2 Posted : Monday, November 9, 2009 2:52:07 PM(UTC)
A Model Number may help others help you.
Where is it, what is it attached to? Just need a better descriton of the problem.
It should be on a separate line. With a Model Number I may be able to find an install sheet. This also depends how the kitchen is set up and the house wiring and of coarse the local electrical code.
