My neighbors Jenn-Air wall oven works fine but has no display at all. I was told I ned to order the display AND control board part#5765M304-60. :mad: However, just the display is bad. Can I just order and replace the display itself which I believe is part# 5765M304-60? :confused:
If I can just replace the display is it a simple plug in or connect application, or would I need to do soldering etc?
I appreciate any help you can provide.:)
THIS FORUM IS DEAD!!!!!!! |
