Hello:
(Note: I posted this on 10/19 and got no replies - I called your 877-# today and the woman I spoke with suggested I re-post it. You can also reply directly to my email if you prefer; janknut@yahoo.com . )
I'm getting a near-constant (goes away a few seconds if you press Cancel) code '-FC-' with beeping on this unit. The only way to 'stop' it is to cut the power at the breaker.
I did not see this code ('FC') listed in your guide, but did see a few related posts.
FC code jenn-air new clock just installed and Alarm FC
Worth noting here is that I had a 'fading LED then no LED' issue one month ago; I replaced a capacitor (the 'C3' specifically) on the control board which solved the LCD issue, so I'm wondering if perhaps the control board ribbon connection getting fussy could be the cause of this, or if I have a more serious problem.
Any / all help and suggestions appreciated.
Thank you, Jan
ps Further information about the prior repair I performed is here:
http://www.fixya.com/support/t3...0_lcd_panel_not_light_up
Hi:
In my case, this appears to have been due to a loose power connection going into the LCD panel control board. It appears that when I did the initial repair, I plugged it in 'just enough' for it to work for a while, until a bump or something similar caused to connection to fail.
-JKT
