lindellmusic
#1 Posted : Thursday, January 27, 2011 5:43:25 PM(UTC)
lindellmusic
Someone in the past bypassed the hi limit switch, so i ohm'd out the switch and found that it was stuck open. I replaced the switch and wired it back the right way. Now we are getting a code F3 which im told means hi limit switch. What could be throwing off the hi limit?
#2 Posted : Friday, January 28, 2011 2:33:26 AM(UTC)
Replacement parts for W131B models | AppliancePartsPros.com
I could not find any tech info on this but when I look up a listing Jenn-Air F3 comes up as an oven sensor problem. This may not be correct as it was just a general F listing for Jenn-Air.
Here is a good link with info on how to check it.
http://www.applianceaid.com/elecrange.html
Jenn-Air wall oven clock blinks (Oven Repair (including Ranges and Cooktops))
by papaaustin 1/30/2013 9:52:57 AM(UTC)
Jenn-Air Wall Oven buzzes and no Display (Oven Repair (including Ranges and Cooktops))
by Joey32 11/15/2011 9:12:08 AM(UTC)
Jenn-Air wall oven - No Display (Oven Repair (including Ranges and Cooktops))
by randykluber 8/24/2011 8:25:38 AM(UTC)
Jenn-Air Wall Oven - Beeps with Code 'FC' (Oven Repair (including Ranges and Cooktops))
by Janmon 10/27/2010 3:12:16 PM(UTC)
Jenn-air wall oven not maintaining target heat (Oven Repair (including Ranges and Cooktops))
by rhiller 9/21/2010 8:48:03 AM(UTC)
W141 Wiring Diagram - Jenn-Air Wall Oven (Oven Repair (including Ranges and Cooktops))
by dugantr1 11/14/2009 5:10:18 AM(UTC)
Jenn-Air Wall Oven - Electronic Control Convection (Oven Repair (including Ranges and Cooktops))
by Cilly 11/9/2009 1:45:57 PM(UTC)
Jenn-air wall oven control panel noty working (Oven Repair (including Ranges and Cooktops))
by fritz 10/8/2009 8:44:55 AM(UTC)
Jenn-Air wall oven (Oven Repair (including Ranges and Cooktops))
by Mike Hallada 10/3/2009 12:14:35 PM(UTC)
Jenn-Air Wall Oven Light Won't Go Off (Oven Repair (including Ranges and Cooktops))
by ThorntonCJ 8/29/2009 12:09:14 PM(UTC)
F3 error on Jenn-Air Wall Oven (Oven Repair (including Ranges and Cooktops))
by lopez 6/26/2009 5:17:07 AM(UTC)
by Brian Breazeale 11/16/2008 4:25:53 PM(UTC)
Jenn-Air Wall Oven display (Oven Repair (including Ranges and Cooktops))
by tyke58 11/8/2007 7:49:46 AM(UTC)
