JNOLES
#1 Posted : Sunday, November 23, 2008 9:52:21 AM(UTC)
JNOLES
My washer overflows approximately every fourth wash load. It appears to be a water level switch or the valve assy. Can any of these parts intermittenly fail? Is there a way to test the valve assy or the water level switch? I am thinking one of the solenoid on the valve assy is getting hot after the fourth load and staying open allowing it to overflow. If anyone has any idea as to what it may be or what I can try let me know. Thank You in advance for your help.
#2 Posted : Sunday, November 23, 2008 11:36:10 AM(UTC)
Unfortunately the both can go bad intermittently.
One way to tell may be to unplug the unit when it is overflowing, it the unit continues to overflow then it is the valve since it is staying open with no power applied to it.
SublimeMasterJW
#3 Posted : Sunday, November 23, 2008 11:50:04 AM(UTC)
SublimeMasterJW
Try removing the rubber tube from the water level switch and blowing it out. Might be some sand or strings down there. Make sure the tube is nice and snug on the switch. Pump the water out and retry.
Washer overflows (Washer Repair)
by pecosb1 8/19/2015 10:25:20 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 5:15:59 PM(UTC)
GE washer overflows after agitation unless extra small load WCXR1070TAWW (Washer Repair)
by Larry75243 9/16/2013 2:10:36 PM(UTC)
washer overflows on xlarge load only (Washer Repair)
by FRVMAN 9/1/2013 9:33:24 AM(UTC)
Kenmore Dishwasher overflows to the floor (Dishwasher Repair)
by goingjumping 2/17/2013 6:03:47 PM(UTC)
washer overflows and unbalance load displayed (Washer Repair)
by allen9258 1/27/2013 10:41:58 AM(UTC)
Maytag Washer overflows on rinse only (Washer Repair)
by basgetar 5/9/2012 8:40:29 PM(UTC)
Washer Overflows Except with Cold Water (Washer Repair)
by jimponti 1/15/2012 8:43:01 PM(UTC)
Dishwasher overflows when using sink (Dishwasher Repair)
by Phil69 12/30/2011 6:51:49 PM(UTC)
Maytag washer overflows during agitation (Washer Repair)
by TexasTaylors 5/28/2011 11:18:42 PM(UTC)
Washer overflows AFTER 1st agitation (Washer Repair)
by Huff360 10/4/2010 9:36:29 AM(UTC)
GE Washer Overflows (Washer Repair)
by vbiondillo@norhill.net 8/3/2010 3:53:03 PM(UTC)
Washer overflows - sometimes (Washer Repair)
by psunittanylion 7/6/2010 12:48:24 PM(UTC)
Washer overflows when set at large load (Washer Repair)
by Victor Scott 6/7/2010 12:46:52 PM(UTC)
Kenmore washer overflows on rinse cycle (Washer Repair)
by montani 5/18/2010 3:00:23 PM(UTC)
