FRVMAN
#1 Posted : Sunday, September 1, 2013 6:33:24 AM(UTC)
FRVMAN
My washing machine overflows out from the drain pipe in the inside rear of unit when used on x-large load only ??? Any ideas what could cause this was thinking possible water level switch but I no longer have the parts manual ?? Any help would be appreciated ..
fairbank56
#2 Posted : Sunday, September 1, 2013 7:52:29 AM(UTC)
fairbank56
Groups: Expert
Check the pressure hose where it connects to the air dome on the lower left side of the tub. Clean out any gunk in the hose and air dome. If that doesn't do it, replace the switch and hose if necessary.
GE WH12X10108 Switch Pressure - AppliancePartsPros.com
GE WH41X365 Pressure Switch Hose - AppliancePartsPros.com
Eric
