t1572
#1 Posted : Friday, November 21, 2008 3:39:59 PM(UTC)
t1572
washer fills but won't agitate .the agitator moves but it just motor hums.it goes into the spin and rinse cycle fine just doesn't agitate in any cycle. tried to take agitator out but can't get it off.
please help t1572
Drags1998
#2 Posted : Friday, November 21, 2008 5:40:43 PM(UTC)
Drags1998
Check the #310 in the parts book, Remove the agitator by pulling up with a quick jerk, The coupling is SPLINED onto the tramsmission shaft, you should NOT be able to turn it by hand. If you can turn it with ease, the coupling IS BAD!!!!:)
t1572
#3 Posted : Saturday, November 22, 2008 10:46:49 AM(UTC)
t1572
I've tried pulling up on the agitator it seems to be stuck any ideas?
libertyappl
#4 Posted : Saturday, November 22, 2008 11:14:20 AM(UTC)
libertyappl
They are sometimes hard to get off, i've seen some posts where they used a rope and a 2 x 4 to pry it up.
Nat
t1572
#5 Posted : Saturday, November 22, 2008 2:26:04 PM(UTC)
t1572
finally got it off
thanks for the help
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Washer won't agitate, spin, drain, but motor runs (Washer Repair)
by dmbailey0321 6/26/2018 11:36:55 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Whirlpool Washer Won't Agitate/Spin (Washer Repair)
by Shazaam 9/1/2016 2:47:46 PM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Washer won't agitate (Washer Repair)
by lap 8/2/2015 9:04:46 AM(UTC)
Maytag top-loading Washer won't agitate, spin or drain (Washer Repair)
by coastalhousewife 6/30/2015 5:37:07 PM(UTC)
Whirlpool washer won't agitate (Washer Repair)
by jmorgan5041 6/11/2015 12:26:59 PM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
Matag Washer won't agitate, does everything else (Washer Repair)
by Jcpstrat 3/11/2015 12:00:16 PM(UTC)
washer won't agitate, but it spins (Washer Repair)
by dee021263 11/10/2014 3:22:15 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
