LCPierce
#1 Posted : 14 years ago
LCPierce
I recently ordered a replacement oven igniter for my Amana range. The igniter I received has a 5.25 inch ceramic base. The existing igniter has a 1.75 inch ceramic base. This is the manufacturers recommended replacement part, but is there room for the larger igniter on my stove? Do I need the smaller part? and if so, what is the correct part number.
Order # 1513183
Larry Pierce
LCPierce
#2 Posted : 14 years ago
LCPierce
LCPierce I recently ordered a replacement oven igniter for my Amana range. The igniter I received has a 5.25 inch ceramic base. The existing igniter has a 1.75 inch ceramic base. This is the manufacturers recommended replacement part, but is there room for the larger igniter on my stove? Do I need the smaller part? and if so, what is the correct part number.
Order # 1513183
Larry Pierce
Read more: http://forum.appliancepartspros...p;t=150360#ixzz17dba56ed
http://forum.appliancepartspros.com
magician59
#3 Posted : 14 years ago
magician59
Here's the bake igniter for your oven.
Part number: AP4041245
Crosley Gas Oven igniter? (Oven Repair (including Ranges and Cooktops))
by gospelguy 7 years ago
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 7 years ago
Oven Igniter will not activate (Oven Repair (including Ranges and Cooktops))
by MDThompson 8 years ago
Oven Igniter for Capri (Sears) Propane Stove (Oven Repair (including Ranges and Cooktops))
by BumpyKnuckles 8 years ago
is the oven igniter supposed to go out after oven lights? (Oven Repair (including Ranges and Cooktops))
by dterrasi 10 years ago
Oven igniter glows red but does not heat (Oven Repair (including Ranges and Cooktops))
by TeamCeisel 13 years ago
Oven igniter Magic Chef (Oven Repair (including Ranges and Cooktops))
by Mar4130 13 years ago
Bosch oven igniter repair (Oven Repair (including Ranges and Cooktops))
by soonerhokie 14 years ago
Replaced Oven Igniter Melted Wire Nut (Oven Repair (including Ranges and Cooktops))
by Edward A 14 years ago
oven igniter on, no heat (Oven Repair (including Ranges and Cooktops))
by alelessbee 14 years ago
GE Oven Igniter coil replacement (Oven Repair (including Ranges and Cooktops))
by jeffcorona 14 years ago
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 14 years ago
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 14 years ago
Replace gas oven igniter (Oven Repair (including Ranges and Cooktops))
by JRhein 14 years ago
GE Profile gas oven igniter (Oven Repair (including Ranges and Cooktops))
by Molly648 14 years ago
