LCPierce
#1 Posted : Thursday, December 9, 2010 8:42:47 AM(UTC)
LCPierce
I recently ordered a replacement oven igniter for my Amana range. The igniter I received has a 5.25 inch ceramic base. The existing igniter has a 1.75 inch ceramic base. This is the manufacturers recommended replacement part, but is there room for the larger igniter on my stove? Do I need the smaller part? and if so, what is the correct part number.
Order # 1513183
Larry Pierce
LCPierce
#2 Posted : Thursday, December 9, 2010 8:47:28 AM(UTC)
LCPierce
LCPierce I recently ordered a replacement oven igniter for my Amana range. The igniter I received has a 5.25 inch ceramic base. The existing igniter has a 1.75 inch ceramic base. This is the manufacturers recommended replacement part, but is there room for the larger igniter on my stove? Do I need the smaller part? and if so, what is the correct part number.
Order # 1513183
Larry Pierce
Read more: http://forum.appliancepartspros...p;t=150360#ixzz17dba56ed
http://forum.appliancepartspros.com
magician59
#3 Posted : Thursday, December 9, 2010 8:50:00 AM(UTC)
magician59
Here's the bake igniter for your oven.
Part number: AP4041245
Crosley Gas Oven igniter? (Oven Repair (including Ranges and Cooktops))
by gospelguy 1/18/2018 1:02:51 PM(UTC)
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 12/4/2017 9:24:14 AM(UTC)
Oven Igniter will not activate (Oven Repair (including Ranges and Cooktops))
by MDThompson 12/27/2016 4:05:57 PM(UTC)
Oven Igniter for Capri (Sears) Propane Stove (Oven Repair (including Ranges and Cooktops))
by BumpyKnuckles 11/26/2016 6:38:15 PM(UTC)
is the oven igniter supposed to go out after oven lights? (Oven Repair (including Ranges and Cooktops))
by dterrasi 12/6/2014 1:54:14 PM(UTC)
Oven igniter glows red but does not heat (Oven Repair (including Ranges and Cooktops))
by TeamCeisel 9/25/2012 4:21:07 PM(UTC)
Oven igniter Magic Chef (Oven Repair (including Ranges and Cooktops))
by Mar4130 8/14/2012 9:26:19 AM(UTC)
Bosch oven igniter repair (Oven Repair (including Ranges and Cooktops))
by soonerhokie 9/4/2011 11:27:12 AM(UTC)
Replaced Oven Igniter Melted Wire Nut (Oven Repair (including Ranges and Cooktops))
by Edward A 6/7/2011 3:44:07 PM(UTC)
oven igniter on, no heat (Oven Repair (including Ranges and Cooktops))
by alelessbee 4/28/2011 8:47:52 AM(UTC)
GE Oven Igniter coil replacement (Oven Repair (including Ranges and Cooktops))
by jeffcorona 1/6/2011 9:35:05 AM(UTC)
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 12/20/2010 8:47:55 AM(UTC)
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 11/24/2010 9:44:06 AM(UTC)
Replace gas oven igniter (Oven Repair (including Ranges and Cooktops))
by JRhein 11/15/2010 7:07:22 AM(UTC)
GE Profile gas oven igniter (Oven Repair (including Ranges and Cooktops))
by Molly648 11/2/2010 1:41:06 PM(UTC)
