tony269
#1 Posted : Monday, October 20, 2008 7:20:51 PM(UTC)
tony269
My washer will not drain. I took the front panel off to see if I could find the problem. Nothing stood out at me, no loose wires nothing in the drain lines. I pulled the drain motor to check it and it works fine. The only other thing I can think of is the timer. Thanks for your help in advance.
tony269
#2 Posted : Tuesday, October 21, 2008 10:53:36 AM(UTC)
tony269
OK so I finally found the problem. It was the lid lock/switch. If this part goes bad it will not let the washer drain or go into the spin cycle. This washer would let the agitate cycle work with the lid up but it has to be down to drain or spin.
v2k04
#3 Posted : Tuesday, October 21, 2008 10:59:17 AM(UTC)
v2k04
yes Frigidaire doesn't brake the tub at the end of spin they lock the lid till it's safe to open lid. The switch making contact is what supplies the motor with power to spin
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
